Need to know why it’s leaking? Is it loose, over tight, cross thread, no washer etc?
I’d guess a copper washer and a bit of gasket paste would fixed in but are you just papering over the cracks. When, how and why did it start leaking?
Why? most likely factors others already mentioned:
1. might need to replace crush washer between bolt and oil-pan. Use aluminium one since they crush easier and gives better seal. Replace each oil change. Amazon - 10-pak drain washers
2. did you use torque-wrench to install oil-pan bolt to proper tension? Harbor Freight 3/8" torque wrench
3. bolt not cross-threaded into buggered hole?
Fix all these and it wll stop leaking. If you don't do anything to fix it, leak will continue and get worse. It'll drip oil onto your rear tyre and cause you to crash and die.
Reactions: tary preisser
