Have you actually tested for spark and saw bright blue spark jumping each plug???
Have you actually tested for spark and saw bright blue spark jumping each plug???I have pulled the plugs and it seems there is spark to each one.
Thanks for the advice. I checked the tank for and didn't see any corrosion. I pulled the plugs and blew air in the cylinders and let them dry out a while. I then put some starter fluid in cylinders right before putting the plugs back in and tried to fire it up when it ran for about 1 second.If you still have it apart pull the spark plugs out and spin the engine over to get any residual fuel out. Blow out the cylinders with some compressed air and allow them to dry for 15 minutes.
Verify spark to each of the spark plugs and reinstall.
Try starting it as normal. No WOT. If that fails try starting it on some starter fluid to see if it runs. Don't give it any gas with the throttle.
Inspect your fuel tank for corrosion.
That's great news!Thanks guys. I completely tore down the fuel pump and cleaned everything thoroughly. After reassembling it, I tested it outside of the tank and it seemed like everything was working fine. Then I reinstalled it and the bike fired right up. =)
