Hey guys, having a bit of a problem with my headlights. They only seem to work about half of the time. Sometimes when I turn the ignition on they work and other times I get nothing.
I've checked the two connectors under the left ram air cover as well as the headlight fuse.
What else should I check? Could it be a chafed wire in the harness that is grounding on the frame?
Check the kill switch
I did check inside the starter housing like that write up mentioned. All of the wires were securely soldered in place.
Any other ideas?
check the black socket that holds the bulb itself an internal short is a common issue
my mate had this problem on his 04. ill have to ask him wen i see him later but it had something to do with a pin in the ignition or some **** and the key
