1 - 17 of 17 Posts
just finished PcIII usb, filter and Hamaguchi full install.
I first had an issue when i was thrown error code 14 to which i reconnected the Number three injector and solved that problem.
Now onto the next issue.
I start the bike and the rpm's shoot straight to 5000-7500.
I have tried adjusting the throttle cables in everyway to make sure that wasnt the issue, but shouldnt it have done this before the PcIII was installed if the avbles were the problem?
Anyways does anyone know what could be going on? or has anyone else had this same issue?
Post Whore Extraordinaire
did u set the 0% throttle position.
sound like thats the issue.
Yep - throttle position sensor. Check your connections
checked tps took off the entire pc system and now it will not idle with the stock ecu.... could i have messed something up? i have checked all the connections and still have the same problem....
i adjusted bad to the original location... any one else?
Did you connect your PC to the right injectors? It goes on the bottom ones, not the first ones you see.
^ yeah what he said.
you might wanna go on www.powercommander.com and try again, cause you definately missed a step somewhere.
they were on the lower injectors. not the upper. but even with the PC completely unpleggued it will not idle now. i checked and rechecked the TPS but it still will not idle.
When you turn the key to 'On', does a light blink in your instrument cluster? If so, your bike is throwing a code. You'll need to count the blinks and let us know or look it up in the appropriate Service Manual.
did u do the green connector 1st, starting left to right, from the clutch side to the other?
then connect the TPS plug?
did u plug the OE connectors into the other end of the PC connectors?
Did you set the 0% throttle setting using the software?
You mustve missed a step, that swhy its fuctup.
just to be sure, double check to make sure your throttle isnt stuck open.
when i get home from work im gonna go over every connection and see ifn something could be crossed or what not... and as of last night there were no codes being thrown. but ill let you know how it goes for sure.
so youll never want to hear what i did but im going to tell you anyways, i put two paper towels to keep something from falling into the Throttle bodies, and well i only pulled one out the first time. BUT i got the bike running and all i can say is WOW the pipe sounds amazing, but i need a custom tune. thank you all whoa tried at helping. and hopefully some one else can learn from my mistake.
so u had a paper towel in there, lol thats a new one for me, hahah.
Gald its sorted out tho.
hahaha. stupid crap always happens. I work in an engine overhaul shop for airplanes. once a engine came in for a 200$k overhaul because it swallowed a hammer a mechanic left next to the inlet. Yep, good thing it didn't swallow your towel.
Discussion Starter #17
yea its always something so small, oh well im loving it now..
1 - 17 of 17 Posts
