1 - 3 of 3 Posts
bike starts but stops running as soon as starter button is released. Don't hear fuel pump priming, instrument cluster comes on but instrument cluster illumination goes off when starter button released
help
i had the same problem you had.
under your left mid fairing...there are couple ground wires that are bolted into the frame. mine oxydized and rusted...i cleaned it with rubbing alcohol and never had the problem again. hope this helps.
and check to see if any wires near your exhaust is touching your exhaust...they may get too hot and cause a short. (another problem i had with my stock bike that caused the same problem you're having)
Found the problem, there is a fuse holder a couple inches from the battery in a RED wire with white stripe. Took the fuse out and found a whole lot of corrosion in it. Cleaned it out, problem solved, thanks:01_thumbu
1 - 3 of 3 Posts
