Is it in the center of the engine under the tank? Do I need to remove plastics and tank to replace seal? Any help greatly appreciated. Thanks
Perfect, thanks I was wanting to make sure before I went into taking it off. Is it mandatory to drain the system before I do this replacement?
So no big deal just clean that, replace seals and refill sytem. should be pretty straight forward then. Thank you for your response and help. heading to garage now to do the work.
pm me if you want the 05CBR600rr factory manual. you got to remove the throttle bodies to get to it.
