1 - 9 of 9 Posts
BOTM winner 8/13
My buddy's 05 600rr has the tst style tail light with no turn signals, but anyways the front turn signals don't work now, any suggestions ? Thanks in advance.
You don't need rear signals for the front or the rear to work.
What signals are in the front? Flush mounts?
If they are led's you don't have enough load on the flasher relay to make them flash.
If the lights aren't turning on at all even on the cluster then check your fuse to make sure it's alright. Sometimes when putting in a new taillight the fuse can pop. Not sure why but it has happened to us as well.
Get this
http://tripageled.com/store/index.php?route=product/product&path=41&product_id=58
wire it in like this.
http://www.600rr.net/vb/showthread.php?t=114102
If they are LED flush mounts then yes you need a flasher relay, you only need 1. Tripage sells them and with our model years you have to hard wire it in. I just installed mine a couple weeks ago and it was a breeze. I used a how to guide on here and found a youtube video where the guy installed the same thing on an 05
You only need one per bike as stated above.
1 - 9 of 9 Posts
