1 - 1 of 1 Posts
Headlights don't have power at the switch and neither does the kill switch have power. The headlights don't turn on of course. The gauge cluster turns on but there is no priming sound of the fuel pump priming. I check all the fuses they are fine. I took apart the kill switch and headlight switch and cleaned the contacts. Still nothing doesn't crank and no headlights. I disconnected the power commander to the stock setup and nothing. The key switch has power to it and from it. If it was a bad BAS then it would still crank and still have power at the switches. I have no idea what to check next any help would be appreciated. The bike has 10,000 miles on it.
1 - 1 of 1 Posts
