look at images by my name, ignition switch. I put this engine in a banshee frame. I overroad the bank angle switch and got it to turn over.Now the problem is, Im not getting spark. i was told its because i don't have the ignition switch.My question is. Can i override the ignition diode.so the engine will fire? If so how do i do that. Any help would be great. THANKS
Are you referring to the diode that drops the voltage to the ecu?
First take a multimeter and test the wires to see the voltage one of them should be 9 volts not 12. On my bike it was the pink wire what I did to test if that was the problem is cut the wire and use a 9 volt battery to see if it will start then. This worked perfectly on my 03 not sure if the 06 is the same
My plug only has 2 wires a red and a red w/black stripe. There is no pink this model don't have it. so now what. lol
