1 - 13 of 13 Posts
i have an 06 600RR with 5600 miles. bone stock.
i was searching but couldn't find anything that helped...
i started my bike like at 12:30 today...
the idle sounded a little different.
i let it warm up for a while.
the idle dropped to like 500
i gave it a little rev up to 2500 and it stopped.
i tried starting it again but it wouldn't and it drained my battery.
so i then i rode down my driveway and popped the clutch and it started right up.
but then i was letting it idle for a little. but then it turned off AGAIN!!!
WTF!!!
what do you guys think?
wow that is weird. maybe it is not getting fuel to the engine maybe you fuel pump is bad or something of that nature or maybe to low on oil
Has the bike sat for a period of time ? Just take it out of storage or anything?
What kind of exhaust do you have. if it is an aftermarket exhaust and you didn't re map the computer then it might be running rich and fouled out the plugs
clogged fuel filter (if there is one)...just throwing out ideas
if you let your bike cool down (like for 4 hours) then turn it back on, does it start? maybe your idle control is turned too low? there should be a little knob near your left alternator case sticking out. try turning it to increase your idle?
Make sure your idle is set to around 1200-1500 after it has warmed up.. 500 is too low. As post above its the black screw knob next to alternator cover, clipped on to coolant pipe
1 - 13 of 13 Posts
