1 - 2 of 2 Posts
ECU won't without at least modifying the wiring harness. I would highly doubt it would work at all. Differences in sensors, engine differences, etc. would be too likely.
Fuel pump probably will but may require a different connector or just cut off both ends and solder them together. You could look them up in a microfiche and see if the part numbers are the same to make sure though.
1 - 2 of 2 Posts
