1 - 2 of 2 Posts
07 with 18.7k on it is having a headlight issue that isn't the bulb. Tried the bulb from the high beam and checked the fuse / relay and both seem to be good. The high beam does still work. Loose connections? bad ground? any opinion or thought would help, thank you.
Nevermind fixed it myself.. Completely disconnected from the two wires coming out of the low beam, don't know how that happened today but it did
1 - 2 of 2 Posts
