Light is indicating "low oil pressure". Not oil-level.
Could be result of:
  • clogged oil-filter
  • improper oil-viscosity
  • overheated oil
  • bad oil-pump
  • bad oil-pressure relief valve
In any case, stop riding bike until you test and measure to determine exactly WHY oil-pressure light is going on.
Also jumper DLC port and read flashing codes. What are they? May be or may not be related to oil-pressure light.
Discussion Starter · #3 ·
Thanks, I will start with changing the oil and filter. Dont think the person i purchased from ever did that.
Should i replace the pressure relieve valve the same time? Or start with oil change?
yeah, start with oil change. Always use full-synthethic oil. Fill to upper line on sight-glass window.
