1 - 12 of 12 Posts
Most of this stuff is off a 07 but some from 09. I think the ECM is only thing off a 09 that would be different from 07. I also have some stuff not listed and also not pictured. Please PM me for prices and if more pictures are needed.
UPDATED:
Left and right OEM mirrors - SOLD
Left and right OEM rearsets
Passenger pegs
Fuel pump
Gas tank with no key for door
New right mirror and mount
Rocker cover
Oil pan
Cooling fan
Tip over sensor, sensor is good but tabs are broke
Starter
OEM rectifier
ECM off 09
Axles, front and rear
Kush drive
Rear rotors
Entire OEM front brake setup off a 07
Entire OEM front brake setup off a 09
Rear brake setup off a 09
Throttle bodies with injectors
Coolant overflow jug
Sent from my SM-N970U using Tapatalk
Adding this to the list. Stator cover and OEM stator. Works fine but has some rash. Would be perfect for track or with covers.
Bump, everything listed still for sale. Make an offer, need to move this stuff
Discussion Starter #11
Does the 09 ECM work fine inside the 07 model?
I think so but I'm not 100% sure. If I remember right they were the exact same connectors and should work but I can't guarantee that.
You need to move one pin, cam position sensor, I think. Look up 07 ECU in an 09 and do the opposite pin move.
1 - 12 of 12 Posts
