So i was riding today and everything was fine, so i stop my bike for a minute and get off to check something. Its fine but then i get back on my bike and the speedometer is blank. The only thing that shows is the clock. Please help!
Speed sensor? That was what was wrong with my 2003.
On the 2007 the fuses are under the seat.
Not enough voltage in the batter can cause the speedo to blank out but the bike to keep working, to a degree. How old is your battery?
If main fuse and sub fuses are good, it's your ignition or related components/connectors. Follow the wire as it curves under the right fairing (you have to pull it back partially) Jump the brown pin and your bike should light up.
