Ok so i did search for my problem came up empty so here it goes. Its kind of long so please skip to the bottom 2 paragraphs for the main question. Sorry
Some back story. I have had the bike 5 years. Still on stock battery. Never had it hooked up to trickle charger so it has run dead many times over the various winters from the cold.
Last season I couldn't start it no matter how many times i started it. Turned out the gas was old, so we siphoned it out and the thing started up after a few tries with fresh gas and a fully charged battery.
Fast forward to today. Battery seems to hold a charge though not great. It died on me at work today. I grabbed the trickle charger from home and it wouldn't start.
Charged it again and it started this time. But after about 10-30 seconds it just died from idle. Last time this happens it was because of the gas. But I just put a fresh tank in 3 days ago.
After starting it 3 times and having it die shortly after idle for a while (didn't even have time to put on gear before it died) i just pinned the throttle to keep the thing alive long enough for me to ride away. And sure enough didn't have a problem at lights or anything else.
So finally my question. It the bike will start even with a battery I'm sure isn't fully holding a charge then why is it dying after the bikes already running? Once its on shouldn't the battery play no role in the bike at all?
I want to fix this tomorrow. Do I need to go buy a new battery or is there something else wrong with the bike that needs replacing? I don't wanna blow my money on a battery if thats not the issue.
any help is appreciated. thanks
*BOTM Feb '11, Mar '12*
Hmm, hard to pin point since you neglected the battery as well. I would replace the battery with a new one and see if that cures the problem. For the future, if you're not going to start the bike up for a while pull the battery out and put it on a charger. The OEM will last a long time with good maintenance but repeated on/off will only shorten it's life.
Just as an FYI, when you drain the battery and charge it, it's called a deep cycle. Car/motorcycle batteries aren't meant to be deep cycled unless specified (like car audio batteries or Optima yellow tops).
Leaving it sitting at idle isn't going to put any charge into the battery, you need to get the revs up for that to happen.
Get a new battery and you will be fine...
And when it comes round to winter again, disconnect your battery. It's going to last a lot lot longer if it's disconnected, then just charge it again before you try using it... also avoid storing it in places that could get down to freezing.
