1 - 3 of 3 Posts
So after looking into it further i realized the coolant leak is coming from the thermostat housing. Is it as easy as replacing the rubber ring and sealing it? What caused this to happen? Will it happen again after i replace the ring and use sealant?
BOTM Winner 10/14
It is possible the sealant/gasket is broken, if you see that it's leaking from your thermostat housing then probably yes replace the sealant and it should stop leaking
So I sealed the housing. Soon after a hose connected to the thermostat housing started leaking, so I bought a new clamp, problem fixed. After that the other side of that hose started leaking, same and now fixed. Now a hose connected to the water pump is leaking!!! Why is his happening?! I'm losing my mind! About to buy a new clamp for that hose and see what happens!
1 - 3 of 3 Posts
