1 - 1 of 1 Posts
Like the title says, I have a 07 cbr600rr.
On my way home from work the other day, the speedo and odometer stopped working. A couple miles later, the hesd and f.i. lights came on and the bikes fueling started feeling a little weird.
The next morning, I wiggled some things around by the speed sensor and it worked for about two miles and then the same thing happened as in the first paragraph.
Since then, I haven't been able to get them to register.
I'm working on getting my hands on a multimeter to start that process. But I was hoping to get a little input from you guys (and girls).
What could be the problem?
Speed sensor, battery, regulator/rectifier. Visually my fuses look fine but I'll check those as well.
As far as checking the speed sensor. Turn the ignition on and test it with a multimeter at the connector?
I looked around for bare wire or a bad ground and didn't see anything.
The bike starts up totally fine.
Thanks
1 - 1 of 1 Posts
