According to racetech the stock springs might even be a little stiff. Does this mean a 165 guy can get away without changing springs?
Track use only
Can you get away yea. Why wouldn't you want a better setup tho for such a small price and for track use only invest in some hundred dollar springs.
weight = 180lbs full gear and use 0.9 to 0.95 kg/mm springs on my 09.
GP front valves and H604A Ohlins rear.
would try 0.85 next as i am not using full travel with above springs...
bike weighs about 375 full wet.
IIRC OTF the 07-12 springs are 1.1 kg/mm (for a 225 lb rider????)
