Hello gents,
Can someone take a picture of your stock coolant reservoir mounting brackets? The service manual isn't much help and I can't find a good picture online.
Thanks in advance!
Hello gents,
Thanks in advance!
Hi baodown,
Are you referring to the overflow tank? I have a '12 600RR and am about to put the fairings back on it. I'd be more than happy to take pictures for you. It's pretty simple, there is basically a pin on the bottom of the reservoir that fits into a hole on the bracket, and then one 10mm (I believe) bolt holds it to the side.
Let me know if this is what you are inquiring about :)
Good luck!
-Ry
Hello gents,
Thanks in advance!
Hi baodown,
Good luck!
-Ry
I remember the bracket for the bottom of the reservoir but I'm having trouble remember how the top half of the reservoir is secured. A picture will be super helpful if it's not too late!
Thank you!
