1 - 2 of 2 Posts
2009 Honda CBR 600RR California ABS - $3800
Edgar - Contact me here at (323)-683-7893
I bought the bike back in July 2018 with 27,400 miles and as of 10/12/19 the bike has 38500 miles. Registration was paid on April 2019 and is not due until April 2020 so you have 6 months left before paying. Not willing to negotiate over phone, messenger, or text; you must come in person. Please read the history before asking the same questions
If post is still then it is still for sale. Can show the bike at anytime of the week as I work from hom. Will not allow test rides without cash in hand or motorcycle license. Go by the rule, you drop it you buy it.
• Matte Black Aftermarket Fairing from MonsterFairings – Installed Aug 19’
• Brand new smoked headlights – Installed Aug 19’
• Clear Corsa Zero Gravity Windscreen – Installed Jan 19’
• OEM Spark Plugs – Installed Aug 18’ at 27k miles
• K&N Filter – Cleaned & Oiled on Aug 19’
• Valve Check done on July 20, 2019
Intake Side should be at .008 +- .001
1). 008 2).008 3).008 4).008 5).008 6).008 7).008 8).008
Exhaust Side should be at .011 +-.001
1). 010 2).010 3).011 4).011 5).011 6).010 7).011 8).011
• OEM Clutch Cable #22870-MFJ-A40 – Installed Aug 19’
Adjusted to 15mm free play
• Throttle Free Play Adjusted – Aug 19’
Adjust to 3 mm free play
• Vortex Keyless Fuel Cap – Installed May 19’
• Fork Seal replaced by Chris Moto Shop in San Luis Obispo on September July 18’
• EPFA EBC Sintered Road Race Front Brake Pads – Installed Jun 19’
Calipers seals replaced Jun 19’
Motul RBF600 Dot 4 Racing Brake Fluid both rear and front reservoirs
• Bike Master Rear Brake Pads – Installed Feb 19’
• Bike Master 8 LED Rear Turn Signal – Installed Aug 19’
• Shogun SwingArm Sliders – Installed Aug 19’
• Billet Manual Cam Chain Tensioner – Installed and Adjusted Aug 19’
1/2 turn backed out upon tension
• Superlite (#10618R) R87 Series 520 Steel Rear Sprocket 42T – Installed at 30.4k on Nov 18’
• Superlite (#20608R) 520 Steal Front Sprocket 16 T - Installed at 30.4k on Nov 18’
• RK 520 GXW Standard Gold Motorcycle Chain – Installed at 30.4k on Nov 18’
• Pirellia Diable Corsa 2 -- 120/70R-17 Front & 180/55R-17
Front has under 500 miles – Installed May 19’
Rear has under 1000 miles – Installed Mar 19’
• 2013 OEM Rear Wheel Gloss Black
• Chain Slack Adjusted every month or every 500 miles whichever came first. Usually set to 1.25” of slack.
• 4 Oils changes Since Owned
1 with Castrol Power 1 10W-40 full Synthetic
1 with Honda HP4 10W-40 Full Synthetic
2 with Powerline 10W-40 Full Synthetic – Bike seems to like this one the best
Last oil change done on May 15, 2019 and has close to 2k miles on it.
• Suspensions set by Ohlins Dealer to 180 lb rider
Extra Goodies
• 2009 OEM Rear Wheel with Q3. Has about 40 % life left on tire
• Extra Rear ABS OEM Rotor
• Mirrors on Hand for both sides
• Extra Front ABS OEM Rotors
• Pillion Seat
• Oil Filter for next service
• Extra Brake Caliper
• Extra Brakes Pads for rear and front
• Old Clutch Cable
• Rear Wheel Mud Guard
• Extra Rear wheel Spacer
1 - 2 of 2 Posts
