1 - 16 of 16 Posts
I have a 09 cbr600rr that has 2500 miles on it and it wont start. Ive checked the battery and it is good. What is the next thing I should check for? I dont really want to bring it to the dealership so they can rape me for doing an analysis. Thanks in advance.
Sure Batt is good? it's 5yrs+ old.....Batt on my 09 lasted 3 yrs with riding every week.....
killswitch?, fuel pump prime?, getting spark? - hell, is it even cranking over.
you provide a WAY insufficient amount of info to try a TS on this non start problem.
BOTM Winner 07/12
So it wont crank at all or it just wont fire
Original battery. I tested voltage. I am going to try and purchase a new battery.
BOTM Winner 07/12
Do you hear the fuel pump prime when you turn the key on? If the killswitch is on and it wont prime it could be a bad killswitch.
If it won't prime and the dashboard won't light up, but you know the battery is good, then check the fuses.
There is one "hidden" fuse directly on one of the battery terminals. I think it's on the positive terminal. It is not in the fuse box.
1 - 16 of 16 Posts
