Hi guys I have a 09 green and black with brand new pc5 auto tune and yoshi slip on. I have been on the bike since got a good base map and started auto tuning everything perfect. been riding in a lot of rain lately I am in the uk went to ride 2 days ago started like shi* and run like that for 30 secs. I carried on about 10 mins into the ride had a little power wheelie and all the way through 1,2 etc wen I got to the lights it was running shi* again for about a min. when I checked oil it was half way on the glass so I topped up and seems fine again has anyone noticed this before as it never happened before mods thanks
Never heard of slightly low oil causing that before... sorry mate.
low shitty oil can cause chain tensioner failure causing timing to be off n boooom then u have shitty running/missfiring-
Half way on the glass isn't anywhere near low enough to cause that though...
Having so little oil that the pressure drops and fries the tensioner will also cause overheating, again making it run poorly.
My point is that slightly low oil won't cause that.
OP Chances are that you had a little water where it shouldn't have been... nothing much to worry about there.
