So i was changing the front tyre and did the usual inspections and noticed that 1 of the pads have worn much more than the other 3.
3/4 pads are fairly even and have about 4.5-5mm material
1/4 has only about 2.5mm material
What little i know about fluid dynamics, tells me that unless there is a blockage, there should be even pressure applied to each piston once pressure is applied at the lever.... right?
what would be the cause of this?
And would I do any damage if i swapped that pad with another on the opposite caliper?? just trying to get some life out of the set before changing them all out...
any thoughts?
btw.. have Galfer, CarboneLorane SBK5 pads and Spiegler lines if that make any difference.
any thoughts?
