Could you be a little more specific on the year ranges for the bikes? I do like the look of the zx10r calipers from the 09 if that's included. Also happen to know if I would have to run 300 or 330 rotors? TIA
dudebrosef, all the current jap bikes are 108mm. take your pick with which bike you want to get the calipers from, gurrrl.
as for rotor size, you can choose 300, 310, 320, 330. all you would have to do is add a 10mm spacer between the mount and caliper.
i believe oem size for 600rr is 310. someone correct me if im wrong.
if you look at the 08 1krr, youll see a 10mm spacer between the mount and caliper. you could use those same spacers.
:drunk:
