has anyone seen this done before? or is there a simpler way to put a 6 inch rear on a 600, please to educating me, i just picked up a wrecked 600 and im going to throw a 1000rr front end on it, and im thinking if the modification need to put a 1krr swingarm on there is not too large, i would go ahead.
i dont have time to search, im walking out the door, and i know changing parts changes geometry, im not soo concerned, just curious if this is reasonably possibly. thanks
nice sight by the way, and this is my first 600, aside from speed 4 triumphs. im all liter bikes.
making it black, putting better brakes and suspension on it, putting better rims on it, full tit ex, pc, tune, 520 kit geared down for more top, smooth out the low, thats it. im going to use the 600rr front end on another bike, would like to take that swingarm with it and use the spare 1krr one i have on the 600rr.
the 600rr and the 1000rr have the same brakes from few years and 07+ with radial master will send you over the bars so no need to spend the money braided lines and good pads and you can just about stop as fast as the sub 3 second 0-60 so 0to60& back to 0 in 6 seconds and 09+ have optional abs i have regular non abs bike and stop in under 100 ft doing 100 so unless your trying to stunt and do stoppies im making my 600 140+hp like stock1krr has and in the 1/8th 75% of everything is going to have to catch-up and if my lights on it doesn't matter that they were doing 30 mph faster because they still got there last 👍
well i have a spare one, and if thats the only way to throw a 6 on there....why not, if it can be done easier, hot damn, is there a guide to do that on this site?
if you wanna know if it fits, you can either measure between the frame rails and compare that to the width at the swingarm mounts, or take the 600rr swingarm off and measure those mounts compared the the 1000rr. You'll most likely need the linkage for the 1000rr, but the dogbone should fit. Might wanna measure width of those too...
Well, not to sound dickheadish, but if I knew an answer, I'd respond. That said, welcome to the site and gl with your project! Post some pics if you decide to follow through/finish it. Or hell, even post them during the overhaul. We don't care. :icon_salu
Im not sure but Its pretty important that the fron and back wheel are lined up and on center. I like the 1000rr swing arm too, but not enough to take on a project like this. If its easy let me know.
its easy enough to creatively slide that chain outwards up to a whole sprockets width safely, and creatively, seen it done plenty of times on euro streetfighters. i mean on super high power applications it needs to be done "properly" but with only 100-115 rwhp you can do it fine with no issues.
so, anyone run a 6 inch rear without massive issues or fabricating/modification complications?
thanks for the info, ill do some measuring and see whats up tomorrow night. i would PREFER to be able to run a 600 swingarm and whack a 6 inch rear in there, but dont know how simple that would be, ill see what i can figure out.
Doesn't affect handling if you run 190/55-17, use 190/50-17 and it turns in a little slower. Not really noticable untill you at speed in the twisties. I can tell at the track when I swap the 600 and the 1000 wheels.
well then im out of the loop, what kind of forks are you running then if they are not 1krr forks? because in the pics the forks are inverted...is that newer style? im not too familiar with 600s
ahh, now i see, inverted starting at what year? whats the size of those inverted forks?
Related Threads
Honda CBR 600RR Forum
3.9M posts
92.7K members
Since 2003
