Big willow is a fast track and you don't need that much pull down low. if it was on streets of willow i would change the sporckets because there are plenty of 1st and 2nd gear corners, but big from what i hear big willow has mainly high speed corners, most of which can be taken at well over 100mph. new sprockets would be wasted on such an environment, and the possibility of the front lifting in one of the turns...egad.
My vote is to change it after, but it is your call and i'm just a fool with a bike. Good luck and i'll see you there if you are going on september 4th.
