Pros and cons of putting on a 190 or a 180. I've seen a R6 with a 190, again what are the benefits of having one or the other on the 600RR?
You're only going to get more rubber on the road at the extreme lean angles where the 180 runs out of rubber. You won't increase the contact patch any more anywhere else.CollegeRider said:More rubber on the road
bwahahah you forgot the extended swing arm lolcling said:getz you a 210 an lower dat shiizzz, den chrazome its out and holla at dem ho's yall!
