1 - 10 of 10 Posts
Does anyone know if the ECU from an earlier model 03-04 is compatible with a 2005 600RR.
I am in australia and we have the HISS system in our ECU model.
Sourced an 03 ECU and key set and wont start, (cranks over but no fuel pump noise and ignition i think)
Not sure if they changed the computers but i have been told they are compatible.
Has anyone had any experience with this?
I bought the bike stolen/recovered from insurance auction to make a race bike out of it without keys for a good price, but now i am having issues getting it going.
I have tested the tip switch sensor and it is working fine, not sure where i am going wrong.
Checked all fuses and all ok.
Any suggestions?
Thanks in advance
i think they are the same computer but the 05 has a different stock map. other than that dont expect anyone to give you any help on starting a bike without the keys especially being your first post. any joe shmoe can join and say damn guys i lost my keys how do i hotwire a 600RR? you understand
I do have keys for the 03 computer and it doesnt want to work
the bike is an 05 and i was told it would work no worries
it cranks over, but no fuel pump noise and no firing up!
I thought it would fire up, have the computers changed?
so if you really do have that stuff why dont you just swap the ignitions
i have an 03 for the road and i just bought an 05 would be track bike damaged from the auctions without keys.
trying to get it going with the 03 bits but it seems impossible
if you bought the ecu and keyset from the wreckers i would return it and get a refund.
as you are the new owner of the motorcycle, take your receipt to a honda dealer to get them to get you a new key with a matching transponder in it. i have no idea if they have it cut for you, but if they dont take it to a locksmith with the bike to have it cut. remember to put back the original ignition though, thats if you changed it with the 03 keys you got.
I tried an 05 ecu and keys on the 03 and i'm have the same issue as you.So i dont think it will work
It will if you swap the harness as well.
there are a couple sensor that have different plugs...T has a 05 engine on a 04 harness and ive got a 07 pc3 on a 03. it will all work but how far are you willing to cut/solder
1 - 10 of 10 Posts
