I cannot find any info anywere on how to change my temp guage from Farenheit to Celcius???!!! Does anyone know how the manual dosent have it either,can anyone help.
i do believe you just key on, then press select and reset and quickly depress(holding them both down for a few seconds will let you adjust the clock). correct my if i'm wrong. . . ..
Trying to remember for sure key on then push the adj/reset button one changes the mph and the other is the temp. Just play with them both and you can figure it out easily. In Iraq right now so cant go mess with it 1st hand.
Do you not have the manual? I believe you need to push one of the buttons and hold it down till the display changes.
