Purchased 2003 600rr couple weeks ago with a half broken kill switch button (worked perfectly fine but wanted to replace anyways). Purchased a good used kill switch unit and tried to replace today. I was unsuccessful taking off throttle tube, didn't have enough time, had to get ready for mothers day. So decided to put everything back together and figure it out on my day off. After getting it back together I turned on engine but it cranked slower than usual but started, i shut her off and did this about 3-4 times. All of a sudden it just stopped cranking. When i press start button the headlight just turns off and back on. I also dont hear the fuel pump prime anymore.
Any ideas what could have gone wrong ?
if the pump doesn't prime the kill switch isn't satisfied.
the start button shuts off the headlights, that's normal.
Check all the solder connections on the switch and also take it apart and clean the contacts real good. Then try again
