Hello, I was wondering if anybody could help me get my 600rr going again. Long story short my ignition cylinder is destroyed and I want to just put a switch in there instead.
I see there are three wires, and as I understand, the pink wire needs to be at 9V with 12V between the other two. Is that correct? How exactly should I wire my switch up to make this work.
I'm thinking it should be red/black wires on the switch, then from the switch positive to zener diode to pink wire? I just want to make sure before I start cutting and soldering.
Thanks for any help.:smile2:
Nevermind I got it by playing around with a paperclip.
US spec bikes do not have the HISS system, therefore I did not need to bypass it. I did bypass the bank angle sensor though, so if you have any questions on that (or the ignition) let me know.
