1 - 10 of 10 Posts
Hey guys,
Just recently bought a CBR about 3 weeks ago, and been having some battery issues with it (stalled a couple times when I first got it). The bike has 55w HID's in both the high's and low beams, which I assume will drain the battery significantly(I don't ride with high beams).
Anyways, I don't know the problem with the bike so I just assumed it was a bad battery. I bought a battery tender and charged the bike for a couple hours...and then started it up, no problems. Now, when the bike starts the tachometer stays around 1.5-2k. The meter "burps" during idle and it seems like the bike is struggling to stay at those RPMS.
The next day, I tried starting it up, and lo and behold the bike won't start. It struggles to turn over and eventually just leads to the infamous "clicking" sound.
I know 2003 CBR's have an issue with the reg/rec overheating and not distributing power correctly, but I haven't gotten any tests ran on it (I don't have any biker friends as I'm new to the motorcycle scene).
Anybody have any ideas what's wrong? Besides the points that I hit?
Thanks!
I would try a whine new battery for the starting issue. I buy the $35 ones off eBay and they work good for me. As for your idle problems idk about that. Hope I have helped.
Do you have a powercommander on the bike? That would be the culprit of the rpms during idle, my bike does that.
Do you have any FI codes?
I bought the bike without the Manufacturers Owners Manual, I just figured I could buy another one down the road.
I don't want to buy a new battery unless I know what's wrong with the bike itself. I have a guy that I know buy a new battery for his CBR as well, until he found out it was the reg/rec. Just don't know if our situations are too similar.
I do not have any FI codes, and I do not have a powercommander on the bike, if that helps
if the battery isnt new or look to be replaced recently there is a very likely chance it needs to be changed. i wouldn't recommend a cheap batt... just more possible you will be left on side of the road somewhere.
if you have a friend with a cbr600rr then ask to pop his battery in your bike, if the bike dies again and drains his battery then you know you have an issue with the charging system, you can even charge your batt and put it in his bike to see if it holds a charge...
so I woudlnt worry about the reg just yet, you have to get the bike to over 5K in order for it to start turning on,
sounds like you need to charge your battery longer than a few hours, try over night especially with a battery tender,
you can jump the bike with a car (make sure the car is off), then when your bike is on, rev the engine to above 5K with a voltage meter on the battery if the voltage climbs your R/R is fine,
but charge your battery for more than 24 hours, stalling and the HIDs then not running the bike over 5K consistently will drain your battery pretty quick,
i agree do not just throw parts at the bike find the culprit and replace that, but it sounds to me your battery is either drained to far or it has a dead cell and needs to be replaced, this happens if the bike sits without a tender or isnt properly charged,
good luck, if you can bump start it and it will run, but will not restart, then its most likely the battery,
take care!
take care!
Bump started it once, and it started right up. *shrugs
Might just try to bring it to a shop and have them look at it...I just hope they just won't charge me the $90 labor + parts if they want to fix it on the spot.
Get the battery load tested, then get them to check the leakage current on the bike.
Alright, here's a little update on my bike...
First I tested the battery with a multimeter...it read ~12.34v, and when started at 5k it also shows positive signs.
Checked the fuses...and the fuse that dealt with starting the bike looked completely fine.
So now is the R/R. I bought a 2003-2005 R/R from regulatorrectifier.com and just finished installing it. The bike STILL won't start by itself.
The bike can be push started in 1st gear, and all the readings and fuel primes whenever I turn the key.
The issue is when I actually attempt to start the bike....it drops my battery voltage down to 4v which I assume completely kills the battery. After I let go of the ignition, the whole system just restarts again as if the battery died completely and came back to life.
All that's left for me to check is the stator...but I just wanted to know if there is anything else out there that might be the issue?
I've had a friend tell me it might be an exposed negative wire touching some other parts of the bike, thus causing it to not start.
Any thoughts? I really want to start riding again, as I jus got the bike a month ago and put <200miles on it :(
You need a new battery by the sounds of that mate... it's not putting out enough current under load.
1 - 10 of 10 Posts
