1 - 12 of 12 Posts
So I bought my 2004 in July and it never occured to me that the 3rd didn't work. SO I figured the light was blown so I took that as an opportunity to get a Tripage Knightrider 3rd eye.....still doesn't power on. I suspect (hope) its the fuse.
Is this common? Where is the fuse box (LOL rookie I know). What amperage is the fuse? If its not the fuse....what else could it be?
Fuse box behind Left side middle fairing
Remember the polarity on the knight rider.. Hook it up to the battery first, this way you know that it works. T
Moeman which fuse would control the 4rd eye.
Trip this didn't work even before the knightrider was installed.
There is a list on the inside of the cover check it out
off hand i do not remember been a while since i had
my 03
I meant 3rd
thanks moeman
Yeah none of those fuses control it. I'm double checking my work again, I took the upper off to fix the control issue that plagued all gauge clusters in 04 and installed the 3rd eye at that point......I'm not takin all that off again.
my 3rd eye doesn't work either- i don't really care- i just leave it that way. none of my fuses are broken, so i know it's not the fuse.
If its not the fuse its the bulb or the plug itself
the 194 stock bulb is known for not lasting that long
Buy the third eye light led from Tripage he got awesome
deal going on
K
Duh. The old light was burned out, and the new light you installed is polar directional. putting it in backwards will not make it light, it's not an incandescent lamp, it's a Diode. only works in one direction.
1 - 12 of 12 Posts
