Changed out the fuel pump on my bike with a Quantum brand pump. Got everything back together and now it won't start. The fuel pump will prime and the motor will turn over just fine but won't fire up. Any suggestions?
open and close the ignition switch few times so the fuel lines filled up with fuel.i had the same problem when I change the fuel pump
Ok I tried that it didnt work. Its turning over like new. The pump is priming just like it did before it went bad. It's a new pump but just the pump not the assembly. Everything looks and sounds normal. Just will not fire up. Any help will work.... thanks
check all the fuses,injector plugs,spark plugs,make sure that the battery is good and finally make an ecu reset like the manual says.
