1 - 20 of 90 Posts
Engine Type 599cc liquid-cooled inline four-cylinder
Bore and Stroke 67.0mm x 42.5mm
Compression Ratio 12.0:1
Valve Train DOHC; four valves per cylinder
Carburetion Dual Stage Fuel Injection (DSFI)
Ignition Computer-controlled digital transistorized with three-dimensional mapping
DRIVE TRAIN
Transmission Close-ratio six-speed
Final Drive #525 O-ring-sealed chain
CHASSIS/ SUSPENSION/ BRAKES
Front Suspension 41.0mm inverted HMAS cartridge fork with spring-preload, rebound- and compression-damping adjustability; 4.7-inch travel
Rear Suspension Unit Pro-Link HMAS single shock with spring-preload, rebound- and compression-damping adjustability; 5.1-inch travel
Front Brakes Dual radial-mounted four-piston calipers with 310.0mm discs
Rear Brake Single 220.0mm disc
Front Tire 120/70ZR-17 radial
Rear Tire 180/55ZR-17 radial
DIMENSIONS
Rake 24.0 degrees
Trail 95.0mm (3.7 inches)
Wheelbase 54.5 inches
Seat Height 32.3 inches
Dry Weight 361 pounds
Fuel Capacity 4.8 gallons, including 0.9-gallon reserve
OTHER
Available Colors Red/Black, Metallic Silver/Black, Black/Tribal, Black
Model ID CBR600RR
Going as fast as I can....the site is loaded down big time. I will post all the pics as soon as I can upload them to my site.
Discussion Starter #14
RR, you beat me to those too. Man is that site dragging.
So, who else is now just a little depressed that they have an old model :cry:
1 - 20 of 90 Posts
