Well, Unless you or the previous owner removed the blinker wiring from the harness it should be under the mid fairing. Have you removed them yet? Are there OEM lights installed now?
it didn’t have front turn signals when i got the bike. and i just saw today that there was some wires that have been cut off. and i’m thinking they must’ve cut it. idkWell, Unless you or the previous owner removed the blinker wiring from the harness it should be under the mid fairing. Have you removed them yet? Are there OEM lights installed now?
mine has blue/green on the right, and orange/white on the left. is it gonna be a unplug the old wire and plug in the new wire which is in my new turn signal? or do i need to connect wires like hard wiring it?I can't see the color codes on the wiring but my 04 is Orange, green, and orange/white on the left and L. Blue, green, and L. Blue/white on the right. I can't say for sure whether you have the same color code as I think Honda changed it on the 05-06 models. But if it isn't that color code it should be something real similar. The white striped goes to the running light and the solid color to the turn signal. Green is ground.
now i understand. okay cool!!! thanks!!!You need 3 wires for each light on the front. You can look on eBay and see about finding some OEM PIN connectors for it, buy another set of PIN connectors, or solder them together. Either way, you'll need to solder. It looks like the PO cut the PIN connectors off.
Yeah bro, I call that an exorcism! I took about two lunchboxes full of tape, resistors, SkotchLoks, wire nuts, speaker wire, etc. out of my CBR! Like yous guys I put OEM connectors with solder and heat shrink.You need 3 wires for each light on the front. You can look on eBay and see about finding some OEM PIN connectors for it, buy another set of PIN connectors, or solder them together. Either way, you'll need to solder. It looks like the PO cut the PIN connectors off.
