1 - 20 of 146 Posts
To help contol all the posts about the Still to be released 2005 CBR600RR. This will be th offical location for all info about this hopefully remarkable bike. Once the bike is offically released a new post will have all new offical release info. Mods please sticky.
Please do not post in this thread unless it is meaningful, NO GARBAGE.
Available January 2005
An 04 just for comparison
The 2005 CBR600RR incorporates a host of next-generation upgrades that elevate this full-on sport mount to all-new heights.
Features & Benefits
New for 2005
Radial-mounted front brake calipers.
41mm inverted front fork.
New intake port shape and redesigned exhaust for lighter weight and increased mid-range power.
New piston surface treatment for reduced friction.
Fuel injection flow increased to match intake and exhaust system changes.
Frame and sub-frame redesigned for lighter weight while maintaining superior handling characteristics.
New bodywork more closely resembles RC211V and reduces weight.
Redesigned top triple-clamp allows for lighter weight.
New swingarm assembly redesigned for lighter weight.
New two-piece shock design for improved performance and lighter weight.
Available in Red/Black, Black/Tribal, Metallic Silver/Black and Black.
Unique features
Unit Pro-Link(r) rear suspension and swingarm design inspired by RC211V.
Dual Stage Fuel Injection (DSFI) system features two injectors per cylinder.
High-revving engine redlines at 15,000 rpm.
RC211V-style center-up exhaust system.
Centrally located fuel tank increases mass centralization and allows more compact frame design.
Line Beam Headlight features three-piece reflector design.
Engine/Drivetrain
Liquid-cooled DOHC 16-valve 599cc four-stroke inline four-cylinder engine features oversquare bore and stroke of 67mm x 42.5mm.
High-revving engine has 15,000-rpm redline (CBR(r)600F4i redlines at 14,200), wider powerband and more over-rev than CBR600F4i.
Compact engine length (236mm) positions the rider forward for more precise handling.
Iridium-tip spark plugs improve fuel combustion and performance.
Dual Stage Fuel Injection system features two injectors per cylinder--one upper and one lower--controlled by an ECU that senses rpm and throttle opening. Lower injector enhances rideability while upper injector improves top-end horsepower. At lower rpm only the lower injector is working. Above 5500 rpm both injectors are activated. The system uses 40mm throttle bodies.
Denso injectors with 12 holes per injector deliver a finely atomized fuel mixture for optimum combustion efficiency and power.
Auto enriching system is integrated into PGM-FI module, eliminating the need for a manual choke.
Two-stage ram-air system provides a high volume of cool air to the airbox for linear power delivery and incredible engine performance.
Cylinder head features angled valve inset to improve airflow.
Cylinder head features two springs per intake valve and two springs per exhaust valve for optimum high-rpm valve operation and durability.
Direct shim-under-bucket valve actuation ensures high-rpm performance and durability and offers 16,000-mile maintenance intervals.
Light pistons, piston pins and nutless connecting rods contribute to higher-revving engine.
Pistons receive new moly surface treatment for reduced friction.
Double-pivot cam-chain tensioner for cam chain durability.
Right-side starter gears for increased lean angle.
Lightweight aluminum oil cooler.
Smooth-shifting close-ratio six-speed transmission is closely matched to the engine's powerband.
Chassis/Suspension
Die cast aluminum frame utilizes new manufacturing methods to provide optimum rigidity while reducing weight. Frame is tuned for precise handling characteristics.
New 41mm inverted Honda Multi-Action System(tm) (HMAS(tm)) cartridge front fork features spring preload, rebound and compression damping adjustability for precise action.
Unit Pro-Link rear suspension system is patterned after RC211V GP racer. In this system, the upper shock mount is contained within the swingarm rather than the frame. With no top frame-mount for the shock, this unique system reduces negative suspension energy from being transmitted into the frame, allowing optimum frame rigidity and improved rideability out of corners.
Braking system features twin four-piston radial mounted front calipers, dual 310mm front discs and a single 220mm rear disc for optimum stopping power.
Redesigned center-up exhaust system features four-into-two-into-one design for increased performance, aerodynamics, and lighter weight.
Handlebars located below top triple-clamp for precise handling.
Additional Features
Industry-leading ergonomic design features maximum rider comfort for minimum fatigue in all riding conditions.
Centrally mounted 4.8-gallon fuel tank is positioned low in the frame, increasing mass centralization and allowing a more compact design. This design positions the rider 70mm forward for optimum handling.
Plastic tank shell cover protects tank and airbox.
Line Beam Headlight features three-piece reflector design (first in the world) utilizing two H7 bulbs for optimum light distribution, and unique compact design.
Instrumentation is very compact and features tachometer, speedometer and fuel gauge.
Attractive hollow-spoke aluminum alloy wheels feature race spec 3.5 x 17-inch front and 5.5 x 17-inch rear dimensions.
One-piece fan assembly for maximum cooling efficiency.
Maintenance-free battery.
Optional seat cowl.
Compact rear cowl storage compartment for U-type locking devices (lock not included) under the passenger seat.
Pivoting aerodynamic mirrors.
Integrated ignition switch/fork lock for added security.
Convenient push-to-cancel turn signal switch.
Transferable one-year, unlimited mileage limited warranty; extended coverage available with a Honda Protection Plan.
Ownership includes one-year complimentary membership in the Honda Rider's Club of America(tm) (HRCA(r)). Benefits include: discounts, travel benefits, roadside assistance, one year complimentary subscription to Honda Red Rider(tm) magazine, access to HRCA Clubhouse Web site (www.hrca.honda.com), access online to Honda Common Service Manual. For HRCA details, call 1-800-847-HRCA.
Available accessories
Color-matched Passenger Seat Cowl.
ENGINE
Engine Type 599cc liquid-cooled inline four-cylinder
Bore and Stroke 67.0mm x 42.5mm
Compression Ratio 12.0:1
Valve Train DOHC; four valves per cylinder
Carburetion Dual Stage Fuel Injection (DSFI)
Ignition Computer-controlled digital transistorized with three-dimensional mapping
DRIVE TRAIN
Transmission Close-ratio six-speed
Final Drive #525 O-ring-sealed chain
CHASSIS/ SUSPENSION/ BRAKES
Front Suspension 41.0mm inverted HMAS cartridge fork with spring-preload, rebound- and compression-damping adjustability; 4.7-inch travel
Rear Suspension Unit Pro-Link HMAS single shock with spring-preload, rebound- and compression-damping adjustability; 5.1-inch travel
Front Brakes Dual radial-mounted four-piston calipers with 310.0mm discs
Rear Brake Single 220.0mm disc
Front Tire 120/70ZR-17 radial
Rear Tire 180/55ZR-17 radial
DIMENSIONS
Rake 24.0 degrees
Trail 95.0mm (3.7 inches)
Wheelbase 54.5 inches
Seat Height 32.3 inches
Dry Weight 361 pounds
Fuel Capacity 4.8 gallons, including 0.9-gallon reserve
OTHER
Available Colors Red/Black, Metallic Silver/Black, Black/Tribal, Black
Model ID CBR600RR
New fairings, USD forks, Radial brakes, new swingarm... story developing....
Not sure but you may have to be a member of HRCA to login to see the info below and for sure you do to see the preview on the 8th.
HRCA Member exclusive
On Wednesday, Sept. 8th from 6:30pm to 9:30pm (Pacific Time), you and other HRCA Members have an exclusive 3-hour preview to view the new 2005 Honda products on the HRCA Clubhouse website. After 9:30pm, the information will be available to the general public on the Honda Powersports website.
Be sure to come back to the Clubhouse on Sept. 8th at 6:30pm (PT) for your exclusive preview!
http://hrca.honda.com/community/2005models.asp
Now for the info;
From MCN
June 23 2004
New CBR600RR revealed
Honda will reveal a revamped CBR600RR this September with reworked brakes, upside-down forks and Blade-inspired styling.
Insiders who have already ridden the new bike reveal more in MCN, out on Wednesday June 23, 2004.
The brakes have radial calipers and smaller discs on the new model and the engine gets modified internals. Expect titanium valves, too.
The CBR600RR was first launched at the end of 2002, drawing inspiration from Honda's RCV MotoGP bike. Read more about the it by following the link to related bikes.
http://www.motorcyclenews.com/nav?page=motorcyclenews.articles.articleCategory.article&resourceId=1003089&articleCategory=NEWS_NEW-BIKES
Links to all previous 600rr.net posts and repost.
http://www.600rr.net/forums/viewtopic.php?t=13270&highlight=2005
http://www.600rr.net/forums/viewtopic.php?t=13997&highlight=2005
http://www.600rr.net/forums/viewtopic.php?t=14726&highlight=2005
http://www.600rr.net/forums/viewtopic.php?t=15333&highlight=2005
In the MCN picture all they did was photoshop the 1000rr forks and wheel, add the "vents" on the rear cowl, change the color of the bottom to look like the 1000RR, and make the headlights squintier!! Seriously we'll just have to wait until mid-Sept when the dealershow goes on. Unless there's a Euro show before than.
HAHA JK, man are you guys desperate to see that new 05
Not so much desperate but just frustrated on how many people continue to post on this. You know when people dont even bother to do a simple search etc. If people want to know what the latest is they can now come to this one location for the info and anything that is new and worth something it can be posted here. We need to try and keep this clean and not add allot of crud.
Bike Of The Month - 09/05
On my dealer they have confirmed the official presentation on the 12th of September on the Intermot show in Germany.
They might as well start running their FX200 win adds right now. Honda will be bragging about it for ages. :blow:
Resident Leg-Humper Females Beware
Sir Slickniss said:
First to find the real pic of the new 600rr
give that thing a full fairing, i'd have to seriously consider buying one...
F*ck i just bought my 04 RR in April and its already obsolete. Son of a....... :evil:
I was at the dealer yesterday getting my recall done, and i was just shootin the ish with tho owner and asked him what the new 600RR was gonna look like. He told me that tonight was the night to find out. that ish is gonna be all over the net to night. i cant wait. Im a member of the HRCA can i really view it tonight on thier site. if so how.
ok, that's a better angle...bike looks good!!!! not too sure about the third light area w/ that hump, but nice RCV air inlets :rocker: paint...ahhh.... :thumbdown:
...........Patiently waiting for the all black one................
how much does it weigh? power? stats?
ok, that's a better angle...bike looks sweet!!!! paint...ahhh....
Remember those are the European colors so the US market may be different. See top of thread for pix.
Thanks to grblade for breaking this story.
C
Im sure US color schemes will be better. I think the 05 has the upgrades everyone wanted.
1 - 20 of 146 Posts
