1 - 8 of 8 Posts
Changed my plugs, I put them back in the right order. Now, it won't crank!!
Even tried grounding the new plugs out to see if they were firing, and I don't think I'm doing it right.
Any suggestions? Please help...
What all did you take apart in order to get to the plugs? I would start by retracing your steps to the smallest detail rather than assume something is broken. Good luck!
Does the fuel pump prime ?
Blown fuse, dead battery, burnt starter switch contacts, burnt kill switch contacts, wire fell off in the starter switch, dead relay or solenoid, kick stand wire or switch, neutral switch... there are a lot of things it could be....
Yep. More details would help. Like do you get power to guages. Does the starter click, Lights come on, Fuel pump primes... Good Luck.
1 - 8 of 8 Posts
