1 - 12 of 12 Posts
My bike will not start, also i have no high beam indicator on the dash when I toggle the switch.
Whenever I hit the "starter" button , i dont hear the starter relay clicking... Also the high/low switch on the left handle bar does nothing. So i have no lights. Bike is in neutral and the Neutral light shows on the dash.
Fuel Pump primes , so kill switch works . I also checked the battery and it pushing around 12.6 V
Here's what i've done so far:
-checked battery -good
-bypassed BAS
-bypassed kickstand sensor
-bike is in neutral
-checked the starter wire connections at right side of bike
-also checked all the wiring that goes to battery
-ive checked the main fuse as well - thats good
But
I've read another thread that if my headlight fuse is blown the bike will not start.. is this true ON A YEAR 2007 CBR 600RR ?? And what else could cause the bike not the start /no lights ??
Man you were dead right. I checked the headlight fuse and it was blown .. replaced it , bike started without issue. Thanks man .
Among a number of things I've learned from wibbly, the most important one is when wibbly says jump, you jump! When wibbly says rollover, you rollover! This is wibbly's house, you sit down when you pee! :drunk:
1 - 12 of 12 Posts
