Hey my fellow peeps.
I recently did some modification on my 2008 Honda CBR 600RR. I changed the right side clutch cover and replaced all of the fairings.
Once I had finished all of the work. I went to kick it over for a burn, but it was not starting.
The fuel pump is priming and the pistons are compressing. But it is not kicking over???
Any help would be appreciated.
Regards
Dim
Weird. If all you did was the clutch cover and fairings, and the bike was running just fine before this work was done, then in all likelihood your issue is with the installation of the clutch cover. If, as you say, that isn't the problem, then there are myriad reasons your bike may not be starting.
*edit: sorry, this really wasn't much help.
Hey thanks for the advice Wibbly.
I have double checked and it is in the proper way.
But still not starting
Dude. I posted a video of how the sensor installs, and you replied with a picture of it very clearly installed wrong.
The wires point down not up. Install it correctly and your bike will start.
