1 - 3 of 3 Posts
Just recently picked up a 08’ my speedometer shows 0mph, and the fuel gauge hasn’t moved but my tach works. I’ve replaced the speed sensor so far. My blinkers also aren’t working but the dude I bought it from just had the wires for the blinkers put together with connectors, any ideas on what’s up with the cluster?
I am reading the service manual (google it or get one) the if the speedometer and odometer/trip meter indicates "----" says Faulty EEPROM in ECM. If the odometer works but not the speedometer, faulty speedometer in combination meter.
It may not be much help but hopefully you can resolve your issue. Not sure if resetting your ECU helps but you can look into that. Hopefully someone smarter would reply soon.
Hey S0ggy,
Pull the right side upper fairing. You’re going to want to inspect the main harness (gray connector with roughly 30 pins). The pink wire with green striping (on my ‘07 anyway) — if it’s disconnected the Speedo will read “0.” Can you confirm that harness and wires are all good?
1 - 3 of 3 Posts
