Hi Can anyone help with C-ABS I have the normal bar down to throttle issue - bled the full ABS system many times - changed the front valve unit and front power using - cleaned the front calipers and changed the front ABS sensor still having the same probem. I have a 2017 C-ABS. There is plenty about this issue in this forum for 1000rr it looks like the same system and same set of problems.https://www.1000rr.co.uk/threads/fireblade-c-abs-fault.29645/
Hi mate, have you put the bike in diagnostics mode and read the fault code? This will tell you what part of the ABS system has the fault.
I did do that the result was 5-1 and based on that I did the full bleed. This system is so complicated !!
Did you get this sorted? Code 5-1 should be incomplete bleed on the front power unit. It's a bitch to get to as the front power unit is between the exhaust headers and engine block... you also need to bleed the valve unit under the fuel tank to complete the procedure as per instructions I posted in the other thread.
