Since October I've set my Datatool alarm system to winter mode, I also isolated the battery, pos mistake, tried to power up with a fully charged battery, when I turned the ignition on, the alarm didn't power up, the dash display did, headlight on, after a short time the hazard lights started flashing, no response when I tried to start the engine, any ideas. Thanks
Possible mistake on my behalf
Meaning isolating the battery might have been a possible mistake? I’d say your alarm is causing an issue, probably lost its programming. That’s a guess, however.
Thank you Miweber929, if that's the case, can it be reset? or does it mean remove the alarm, thanks.
No idea, I’m not real familiar with the Datatool product. What I do know is what you are describing isn’t a “Honda OEM” behavior (hazard lights flashing) so it has to be an aftermarket thing.
