1 - 2 of 2 Posts
I am bypassing the clutch switch on my 2013. Are the wires in the plug stil Green/Red and Green/White for the clutch switch? I can only find older model wiring diagrams and those are the colors for the clutch switch on them, but those colors are on different pins in the 2013 plug than older models. I also looked for the 2 black wires on the switch side of the plug but there are 3 black wires going into the plug, 2 of them match up to the G/R and G/W, the other one matches up to another black on the bike side of the plug.
Just wanting to double check before I jump the wrong wires.
Thanks!
Don't bypass it. The clutch switch changes the engine behaviour when in gear.
Don't believe me? Pull in the clutch when in neutral and check your idle, then put it in gear and look again.
There's no reason to bypass it
1 - 2 of 2 Posts
