1. To infer from the metal powder in the oil pan, Your knocking sound may be the noise caused by the journal bearing being worn and rotating with the crankshaft.How can I find out if i can reuse the casing or get a new one?
Only way to know for sure is to take it all apart and measure everything. Your crank and rods may be toast. Remove pistons and examine cylinder bores.How can I find out if i can reuse the casing or get a new one?
Do not run the engine.
crankshaft and the engine block will wear out.
2. unfortuntly there is no brand new case from honda. It was discontinued. You have to buy something in good condition on the website.
Ok once it started knocking I killed it and walked her up hill and coasted down to a friend's house and trucked her back home. This is the first time taking a part a bike motor and so far so good for being on the rez. Can I replace the bearings if there isn't to much damage?
i recommend change your crankshaft.Is there any way I can rehab the crank or do I need to buy another or I just heard about metal spraying?
