There is no class for 750's, and they already have one. It's called the VFR800i
750 would be nice thoughThere is no class for 750's, and they already have one. It's called the VFR800i
yes, you would, but you'll also loose stability at higher speeds too. you can also soften the front and stiffen the rear too. pretty much anything that lowers the front end, and raises the rear (effect) will allow you to corner more aggressively into corners. either way you do it, you'll still be compromising the stability of the bike though.QUESTION: Would I improve turn-in with the forks higher in the clamps and the shock link adjusted longer (taller) in the rear?
Why does a class have to exist for 750's for one to be made? suzi still has the gsxr750. The VFR is more of a sport tourer, though i saw many at a recent track day.There is no class for 750's, and they already have one. It's called the VFR800i
