1 - 3 of 3 Posts
So i installed braided brake lines on my bike and now my front reservoir is leaking. I checked all the seals and everything seems to be fine?
also what is this piece called?
BOTM Winner 03/14
Can you upload a picture of it leaking. What lines did you get? How tight did you tighten the bolt? And you did install the washers that came with the kit right?
Looks like the Ram air cover that is the piece that slides into the upper & hooks into the side of the gas tank cover make sure the rubber seal is set even below the reservoir cover 9 times out of ten that is the reason behind such leak
1 - 3 of 3 Posts
