1 - 1 of 1 Posts
Hey everyone, wanted to see if anyone here had dealt with a flashing ABS light? It's a 2014 model. I've read a few threads discussing it but the issue I'm having seems to be different.
I've disconnected/reconnected the battery, checked the ABS fuses, checked/cleaned the sensors, and checked the tire pressure.
Finally went to have a diagnostic on it and the code is 7-6 which points to a rear unit solenoid malfunction.
Dealer is saying they'll have to check all the wiring to this part and then replace the part if it's bad. Said it's a PITA to get to the part.
Just checking to see if someone else has dealt with this before.
Thanks,
John
1 - 1 of 1 Posts
