It will not prevent burnouts. At least the Honda C-ABS does not. This is not a traction control system like the new ZX-10R or the RC8 has.'
It does yes, also prevents burnouts.
Its a great system in my opinion.
Sure. When you're going in for a new tire, why not burn off the old one.does anyone want to do a burnout? somebody who likes wasting money, and vigorously cleaning rubber off of every nook and cranny of their bike?
its such a Fing pain to clean though, seriously a huge mess.Sure. When you're going in for a new tire, why not burn off the old one.
Going hard on either front or rear is supposed to engage the opposite a little bit also. This helps add some braking force to your effort and also helps settle the chassis a bit.Fill me in then because I was under the impression going full hard on the front brake activates the rear as well.
I have a 09 without the abs feature and I was like just got handed a little less than a chance at 50 mph and about as many ft before I go into work truck with a solid steel flatbed and a car in emergency lane but it is what you see me in the morning practice people pulling out in front of you and might not be for everyone but I wouldn't have to think about the other side of the road and no cars for a mile or so but just let you know that since they were given same brakes as liter bikes and radial master cylinder it's able to send you flying before you lock up tires and slot more likely to have back tire break loose double down shifting regardless if it was a accident if you wasn't supposed to be using the front brakes to stop it wouldn't have two much larger calipers and rotors and the front brakes hooked to the lever in your throttle hand it's like a 70/30 spit on stopping force nothing to you just saying it for safety just using the back brakes and it is a good possibility of not being able to get it stopped in time I know we can stop in like a 100 ft from a 100mph just front brakes and down shifting to let it use engine to brake like how semi truck used to doi live in Michigan so you will be riding beautiful sunny skis and the next minute it will be pouring on you. Also we have pot holes so gravel is sometimes all over where traffic light ends. So my question is should I go with the abs model or non abs? im not a racer i just ride for fun around town and freeways.
That was absolutely horrendous to read. It also made zero sense to me.I have a 09 without the abs feature and I was like just got handed a little less than a chance at 50 mph and about as many ft before I go into work truck with a solid steel flatbed and a car in emergency lane but it is what you see me in the morning practice people pulling out in front of you and might not be for everyone but I wouldn't have to think about the other side of the road and no cars for a mile or so but just let you know that since they were given same brakes as liter bikes and radial master cylinder it's able to send you flying before you lock up tires and slot more likely to have back tire break loose double down shifting regardless if it was a accident if you wasn't supposed to be using the front brakes to stop it wouldn't have two much larger calipers and rotors and the front brakes hooked to the lever in your throttle hand it's like a 70/30 spit on stopping force nothing to you just saying it for safety just using the back brakes and it is a good possibility of not being able to get it stopped in time I know we can stop in like a 100 ft from a 100mph just front brakes and down shifting to let it use engine to brake like how semi truck used to do
